It is currently Thu Aug 07, 2025 12:44 pm
 Post subject: repairing a cracked top
PostPosted: Mon May 11, 2009 2:14 pm
Ahh, the dreaded humidity crack from the tail to the bridge...how do YOU repair?
I'm trying my first. After reading here and there on the web, I chose to follow one method involving pressing the crack open from the inside and flooding with CA. Structurally, I'm sure the crack is now fixed...but cosmetically, its now more visible than before the repair...a very dark line in the light spruce top.
To remedy this (I'll try on scrap first), I thought of digging out some of the CA with a very sharp blade, making a very small V-shaped trough in the repair...then filling with Titebond and sanding dust from either side of the repair inthe the glue trough. This method works great for filling small gaps around the bindings and such, thought it may work for this as well.
Can someone suggest a different method?
Jon
PostPosted: Mon May 11, 2009 5:48 pm
D'oh, CA to repair a top!? Hide glue or titebond are the glues of choice for soundboard cracks, because they are easy to clean up and don't make a nasty dark line. Forget sawdust and glue, there is no way that is going to look better than what you have. The method that will probably look the best at this point is to do nothing, poking at it will very likely make it worse, unless you are a master at artistic restoration.
The fix that has some chance of looking ok is to cut or route a channel, from the purfling to somewhere under the bridge following the grain lines, and fill it with a matching splint of wood. This is usually done when a humidity crack will not close without extreme measures. I wouldn't do it in this case though.
This is why probably 80% of black topped guitars are black, i have made a few black ones myself!
Jordan Aceto
Ithaca, NY
PostPosted: Mon May 11, 2009 7:26 pm
The V Trough will blend it in pretty good. Just make sure it matches.
PostPosted: Mon May 11, 2009 7:52 pm
jordan aceto wrote:
D'oh
D'oh, indeed. What web site, pray tell, did this recommended method come from? Should have asked here before doing something irreversible.
I assume this is on a completed, finished (factory?) instrument? Chances are that unless you're an absolute master at filling and touchup, you're just going to head down a long spiral of each step making it worse and more apparent. It was a bad move, but it is what it is now. I say leave it, live and learn.
PostPosted: Tue May 12, 2009 2:23 pm
A trough with sawdust and glue fill is an awful idea. It will look much worse and be structurally unsound. Do not do this.
CA can be used for a tight--no visible gap--crack as far as structural concerns go. But it will mess up the finish and it's impossible to clean off the excess. So it can be a viable repair method during construction (better for back and sides than for the top), but not a good idea after finishing. It's not clear whether this is a completed guitar.
There's probably no way you will improve the appearance. Cutting out the crack and splinting is 99% likely to look worse, and to open up sometime. It is one of the hardest repairs to get looking good.
It probably would be good to back up the crack with cleats.
PostPosted: Tue May 12, 2009 2:47 pm
Ok guys, this one hit home - I've got a 15yr old D28 with this exact problem. I know its not unusual, I just haven't tried to fix one myself. I was planning humidify the guitar, if needed, to close up the crack then warm up the top and work in hide glue. When complete I thought I would put in a few cleats.
Does this sound like a reasonable plan?
PostPosted: Tue May 12, 2009 3:42 pm
Yep, reasonable indeed. I use a long rectangular mirror, that just fits through the soundhole, so that i can see the beads of glue coming through the underside of the top as i work the glue in. The only thing to watch out for, is if the crack is gapingly open, or takes extreme humidity to bring it closed, that is when i start thinking about routing and splinting. It doesn't sound like yours is that bad though.
Agreed, it is about the best stuff for cracks in most hardwoods, especially rosewoods and ebony, before there is any finish on.
Agreed that it is tricky, and not recommended for this case. I just thought i would bring it up, kind of crossing options off the list out loud. It is a valid repair though, up here in the northeast during the winters there are lots of guitars with extreme humidity related cracks, and pretty much the only fix is the splint method, it is a fairly common repair, and not that hard to do well, especially without finish to touch up.
Jordan Aceto
Ithaca, NY
PostPosted: Tue May 12, 2009 4:15 pm
Thanks for the insight, all.
This guitar was my fourth build and is NOT a museum piece. There were enough flaws in the finish to warrant taking it back down to bare wood again, so matching the finish on this repair won't be an issue.
I checked out the reciprocating blade thing by StewMac, supposedly a tool to cut in the channel for a splice. That looks like about the scariest way to do this sort of surgery, if you ask me. Why not just make a straight-edge fence jig from the soundhole to the tail of the guitar, chuck up a teeny-tiny little inlay routing bit in the Dremel, and route a splice channel that way? Nice and square, no fluctuations in width or depth, no "wedging" a splice in....seems pretty fool-proof, really.
Maybe "fool" is the operative word here. :lol:
PostPosted: Tue May 12, 2009 5:09 pm
That is exactly how i do it, i run it underneath the bridge if i can. I use the same jig that i use for routing saddle slots. Fool proof... not quite, but possible.
Back to your original post, i think more has been made of it than it probably warrants, by me mostly. In all likely hood, after the guitar is finished and done the little dark line won't show up too much at all, or at least not enough to loose sleep over, especially if you like a little amber in your finish. We all have those little spots on our guitars that jump right out at us, because we know right where to look for them, but most anyone else looking at your guitar will be much more charitable and less critical than yourself. It is hard to know when to stop poking at it and call it good, and when to accept nothing but perfection, when there is a big roll of the dice for a minor improvement, that's when i am inclined to stop and let it be.
Jordan Aceto
Ithaca, NY
PostPosted: Tue May 12, 2009 7:53 pm
All agreed, Jordan. It's splinting on a finished, aged guitar and matching the color and chatoyance of the splint to the top, and then matching the color of the finish that requires real artistry. I've never been near to mastering that one.
PostPosted: Wed May 13, 2009 6:49 am
No one will be arguing that! The only thing that could make it worse would be a sunburst. I have a friend who is far better than me at those jobs, and i try to send them his way as much as possible.
Jordan Aceto
Ithaca, NY
PostPosted: Fri May 15, 2009 11:32 am
jordan aceto wrote:
I need some advice. I'm working on this right now and after humidifying the guitar the crack is very, very tight (couldn't get any better). But I can't get any movement and am not sure what the proper technique is to work some HHG into this thing.
PostPosted: Sat May 16, 2009 9:50 am
I blob some on and smush it in with my fingers, i press down pretty hard to open and close the crack up and down, which pulls the glue in. I also have a little suction cup, a little bit bigger than a quarter which i sometimes use to force glue in to stubborn cracks, usually i just use fingers though. I use pretty thin HHG for tight cracks. It cleans off the finish no problem, with just a damp rag.
Jordan Aceto
Ithaca, NY
PostPosted: Sat May 16, 2009 9:59 am
In addition to Jordan's technique, I place one arm inside the guitar through the soundhole and push up on the crack with a fingertip. This opens the crack up on top a little allowing the glue to penetrate better. After a minute or so, you can usually see a few small drops of glue squeezing out of the crack on the inside, indicating full penetration.
PostPosted: Sat May 16, 2009 10:35 am
I cross-posted this on the MIMF cause I needed to get it done yesterday and I ended up just going ahead and doing it. But I feel more confident now since I ended doing just what you two described. I also used HHG and added some cleats inside to reinforce the crack. Thanks!
Users browsing this forum: doncaparker, kfish and 38 guests
cron
